7 members (HandyAndy, Tiny, TUTS 59, Southerntruck, 66flea, klhansen, 1 invisible),
88
2
Mod | | | Forums66 Topics128,092 Posts1,056,043 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,058 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,058 | The FAM (Section 1, Sheet 3.09) says shim as required so there's 1.83 +.06/-.00 inches between the bottom of the floor and the top of the frame. You could add more conveyor belt if you're below that amount.
