| | | Forums66 Topics128,050 Posts1,055,670 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,029 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,029 | My take on why there's a stud instead of a bolt on the top mount is that it's easier to stick the starter over the stud than to hold the starter in position and start a bolt. Anything that makes assembly quicker at the factory is usually done. The starter lines up in the hole for the nose, but can be out of rotation to find the hole for the bolt (instead of stud situation.) The stud is coarse thread on the end that screws into the bell housing, so strength at that point is basically the same as using a bolt. Why a fine thread is used on the stud/nut is still a question in my mind.
