| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Car water pumps in 54 used a 3/8 inch wide belt. Trucks used 5/8" belts, I believe. Is the pulley pressed onto the pump shaft, or does it bolt onto a round flange?
