7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost),
126
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | Are you using ported vacuum or full intake vacuum on the advance? When coasting, you should have little or no advance from the vacuum canister if the port is above the throttle plate. Someone has BADLY misinformed you about how a vacuum advance works. It adds about 8-10 degrees of total spark advance (crankshaft degrees) at light throttle cruise, and drops that advance off during open throttle pulling, and usually when coasting with the throttle plate(s) closed. "Ported vacuum" comes from a fitting slightly above the position of the throttle plate at idle, so it's possible your idle speed is set a bit too high if you're getting vacuum at the distributor while idling. Jerry
