| | | Forums66 Topics128,130 Posts1,056,717 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,117 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,117 | It looks to me that the only issue with leaving the assembly bolted to the bellhousing is if there's enough room to get the pedal shaft out far enough to release the pedal. And then maybe to push it back in place. I don't know how tight the shaft would be in the mount. Can you see if the pin goes all the way through? If it does, it's probably a cylindrical pin, not tapered.
I'm just spitballing from looking at your picture. You'll have to confirm it'll work, being hands-on.
