Most 535 flashers (6 volt, positive ground) are rated for a max of four 32 candle power lamps. This one is rated for six 32 cp lamps. Should slow the flashing down some, but I don't know if it would be enough.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12
'52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
