| | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | This is for a positive ground 6v system. Using a Signal Stat 900 DOTQQC76. I want to install a 15a fuse. What would have been the positive wire going into the unit now becomes the negative wire. Is this where the fuse is to be used? The unit does work as a positive ground. I used a 535 flasher, but it flashes as fast as a strobe light. What other flasher could I use?
Rick G
1939 Chevrolet Stake Truck
