| | | Forums66 Topics128,094 Posts1,056,489 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,833 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,833 | Do you have access to a cooling system pressure tester? I'd suggest pumping the system up to within a pound or two below the pressure rating of the radiator cap (probably 13-14 pounds) with the engine warmed up to operating temp and then shut off, and look for seep leaks as it cools down. I've cured small leaks like that by draw-filing the gasket surface of the thermostat housing on occasion. It might be warped slightly so the gasket isn't sealing equally across the whole surface. Jerry
