It might be a good idea to research the airflow those air cleaners are rated for. It wouldn't surprise me to learn that they're a bit under capacity for a 235 engine, especially at highway cruise speed. I run one approximately that size on my Harley, and it's OK for an 80 cubic inch engine. It might be wise to consider using filters that are a little taller, and/or larger diameter on the engine in the photo. Just a suggestion.
