1 members (Southerntruck),
98
6
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | Sounds like a good idea. 455 Buick engines used a motor mount bolt for the ground cable from the factory. I solved a "slow crank when hot" problem for one of my students whose family car had that engine by cleaning the mount with a wire brush and installing a new cable connector and bolt. That one loose, dirty connection was robbing 1 1/2 volts during cranking. The allowable voltage drop was 0.1 volt for any connection. His mother had already bought two batteries and an alternator from local shops before I got to it. Jerry
