I upgraded my lines from tank to mechanical fuel pump with this braided 15ft 8an fittings. 2 kits did 3 trucks. 3/8. Thats 2 panel trucks with rear mounted frame tanks and one tank relocation to under bed. The 2 with 327`s ,I kept the 8an line fittings from pump to carb. and thats just because both engines had HP measured at the line between using 5/16ths or 3/8 ID to carb.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
