| | | Forums66 Topics128,184 Posts1,057,267 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,880 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,880 | The main case fill/check plug is visible at the lower right of your photo. The plug just ahead of the torque tube pivot is for the U joint. That one doesn't need much, just a cup or so. Fill the main case until you can reach through the hole and just barely touch the fluid with a fingertip. Filling the case all the way to the bottom of the plug hole can cause leaks due to heat expansion of the gear lube. The spinning gears splash the lube around inside the case. Jerry
