Slow progress got a few parts cleaned and painted .I took the pinion bearings off the old pinions .have the outer pinion slipped on with the lock ring was going to press the inner bearing on and noticed there is only 8 ball bearings on each side as compared to 12 or13 on the original.Anyone know if this will make any difference .Thanks Kevin.
