| | | Forums66 Topics128,088 Posts1,056,109 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 5,722 24601 | | 24601 Joined: Nov 1995 Posts: 5,722 | John, Judging from past experience, I believe I am quite capable of doing it again...
The grease is a good idea. One of the old timers here told me to put some wheel bearing grease on it (probably same as you). Worked pretty well.
The other trick was making sure the cannister didn't get canted. Now this may all sound elementary to you guys but ole John is just figuring out some of this stuff for himself -- apparently there is a spring in the bottom of the cannister that keeps the filter tight against the engine to make a tight seal? Well that darn spring makes it hard to hold the cannister firmly and squarely --- and if you just let it hang by the bolt and tighten it up, it gets canted or knocks the ring out at the top.
And there wasn't exactly a whole lot of room to work under there, either. Which surprised me.
And who's idea was it to run the exhaust pipe two inches from the oil filter??? I thought one of the jobs of the oil was to help with cooling? Kinda defeats the purpose having the exhaust line pumping heat into the oil filter housing (the side of the cannister facing the exhaust line doesn't have any paint on it from the heat...)
GMC a superior truck?? So far I am not impressed.
:p John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | |
