| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | The coolant can flow either way through the heater core. Flow direction is out of the thermostat housing to the heater core, and the return line goes to the water pump. If there is a cable controlled valve regulating coolant flow through the heater, it's usually better to plumb the "pressure" hose from the thermostat housing to the valve. Jerry
