| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | The rubber bushing needs to grip the outside race of the bearing tightly enough to keep it from spinning. Only the inner race that's attached to the driveshaft should turn. It sounds like you might need to insert some type of shim between the bearing and the rubber carrier to tighten it up a little. Jerry
