Could be the timing is just a tad fast. Or points slightly off. If the cables are big enough for the 6 volt, it should start reliably.
If it sounds like it grunts while trying to start hot, then the timing may be just a little fast. Might back it off a little and see how it does then. Be sure and check the point adjustment too, cause this also will affect the timing.
Good luck.
