| | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2023 Posts: 443 'Bolter | | 'Bolter Joined: May 2023 Posts: 443 | Hi again. Seems like everything I touch needs work.
My brake pedal doesn’t come all the way up after use. I have a new return spring but haven’t figured out how to get it on. Need to know the secret of getting the old one out first.
I’ve tried using channel locks and made up hooks from a coat hanger but can’t get the spring to clear the wire hook on the end. I’m really worried about getting the new one on if it is stronger than the old one.
Sure could use some sage advice.
Doug 1954 Chevy 3100One problem solved doesn’t seem to shorten the list Montgomery, ALIn Project Journals | | |
