If you choose to keep the ground wire there, use a piece of highly flexible wire, like the kind used for voltmeter test leads. The distributor housing on a stovebolt is moving constantly from the action of the vacuum advance, and a regular wire will get metal fatigue and break strands pretty quickly.
