| | | Forums66 Topics128,115 Posts1,056,636 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | That is a polarity reversing switch that is supposed to prevent, or at least diminish metal transfer from one contact of the points to to the other. Each time the starter is engaged, the switch reverses the current flow. Bypass the switch, but at the same time run a ground wire from the rigid point to the distributor housing. That particular distributor has the breaker plate insulated from the housing. Jerry
