7 members (J Lucas, Otto Skorzeny, Chuck52, TooMany2count, Gray_Ghost, Sjm, 1 invisible),
74
2
Mod | | | Forums66 Topics128,259 Posts1,058,305 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2023 Posts: 48 'Bolter | | 'Bolter Joined: Jul 2023 Posts: 48 | Is the seal that fits over the rear bearing called the rear wheel oil seal/rear axle seal? what is the seal that is in the differential that seals the axle as it passes into the differential or is there a seal there? i dropped off wheel bearings and seals to the mechanic and he says i need rear axle seals- does he need another seal? thanks
Family truck 1953 1/2 ton w/216
