Carl,
The idle mixture screw does cause some change in RPM, but not a great deal. I have the cables right. I will check all this on the other 964 I am working on and switch this one out sometime today. I will also look for a hole in the throttle plate.
Thanks
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
