| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,853 | A rust repair patch panel for a 58/59 pickup fender can probably be spliced into the bus fender if the eyebrow area is too mangled to straighten. Unless it's had a really bad hit, chances are a repair like that will be less expensive that replacing the whole fender. Jerry
