As long as the oil level in the pan keeps the pickup screen submerged so it doesn't suck air and cause the pressure to fluctuate, half a quart plus or minus won't make much difference. With the usual canister type filter installed, there's about 3/4 quart trapped in the filter housing after the engine stops and the canister drains to approximately the level of the inlet line in the side. 5 quarts in a filter-equipped engine will put the dipstick level on a stopped engine at or slightly above the "full" mark. Most of that extra quart will stay in the filter canister and won't affect the dipstick level much, if at all.
