| | | Forums66 Topics128,159 Posts1,056,901 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | Are you on the brakes when you're slowing down? Maybe there's an excess load (high resistance short) in either of the rear turn/stop light circuits that pulls the voltage down too far with the brake lights operating along with the turn signals.
Or it's possible that your generator is not working correctly and your battery is on the way out.
You need to get out your multimeter and monitor your battery voltage at various conditions.
