7 members (klhansen, Otto Skorzeny, MickeyP, DadsFirstPickup, Woodcmiami, Hotrod Lincoln, Wayne67vert),
73
2
Mod | | | Forums66 Topics128,043 Posts1,055,609 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,763 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,763 | The "R" prefix indicates "resistor", which was a newer type that the original AC 43, 44, and 45 plugs that did not have an integral resistor in the insulator. Those plugs are virtually collectors' items, and the R series aren't much more common. DO NOT USE a plug with a "TS" suffix- - - -that stands for "tapered seat" and it definitely does not interchange, even if the numbers are right. TS plugs usually have a 5/8" wrench size, rather than the 13/16" flats on a R44, R45, etc. NGK or Champion makes a suitable swap for a Delco plug if the AC isn't available. Just consult a heat range interchange chart. Jerry
