7 members (Jay R, Oswald, 55shaker, Joe H, Jon G, Phak1, dt235sd),
86
3
Mod | | | Forums66 Topics128,268 Posts1,058,391 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2020 Posts: 261 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 261 | Similar to the above, I'm sure it would work fine without a cover, but personally for larger holes I usually make sheetmetal caps (and usually get fancy and play with the bead roller on larger ones), paint them and then screw or rivet them in before I cover em up. After that I have used the butyl backed sound deadening stuff and yes, it works fantastic. And does a good job on smaller holes. I do that as I figure dust/dirt/grime might work its way underneath the surrounding area and maybe cause other issues down the road, although... I'm probably worrying about nothing
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver OT Vehicles: 1925 Hudson Brougham Super Six 1950 Chevrolet Styline (Parts) 1952 Canuck Pontiac Sedan Delivery (Well Underway) 1973 F250 4x4 Highboy 1977 F250 4x4 Lowboy
