| | | Forums66 Topics128,119 Posts1,056,311 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Remove the gauge sensor bulb from the engine, and take the gauge out of the dash. Immerse the sensing bulb in a pot of boiling water and adjust the needle position to 212 by whatever means necessary- - - -bend linkage, change gear position, etc. The boiling point is the important indicator. Let the "cold" setting fall wherever it chooses- - - -you want to get an accurate "overheat" reading to protect the engine. Jerry
