| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I have a 47 1.5 ton with steering box issues. The original box uses a block with ball bearings and a worm witch is worn badly. I got a box off of a early 48 two ton but it is different with a worm and rack. Both need rebuilt witch one is the correct box for the truck witch one will work the best. The box off of the two ton has less wear needing only bushings and new seal will it work as well as the box with ball bearings. | | |
