Problem solved - and it was simple. Thanks Kevin and Dan for your advice. I tightened the packing nut just a wee titch and it leaked even more. I drained the coolant, removed the valve and cleaned it up. Then I wrapped the valve stem and packing nut threads in teflon tape and voila - no leak. With the coolant drained I also replaced all the hoses since they'd been in quite a while. Thanks again for the help!
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
In the Gallery Forum
1998 Chevy Suburban 350 ci awd/4wd
