You guys are a great help. There is no sign of leaks as i can and for what I have as a history it was not an over worked truck. I will drive it after doing some brake work and inspecting outer seals and inspect the hub bearings as Grigg has mentioned.
1946 Chevy 1.5-Ton Flatbed
Photobucket
Old Big Trucks are built to last.
