| | | Forums66 Topics128,266 Posts1,058,140 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 4,531 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,531 | We have an update to an old Tech Tip on "How to Measure Cylinder Taper" by Jerry "Hotrod Lincoln" Herbison that was originally posted July 2017. ------------------- You’ve disassembled the engine and the pistons are out ... You were careful in doing that, right? If there were some ridges at the top, the only correct way to remove a ring ridge is with a reamer designed specifically for that purpose -- Do that BEFORE you attempt to remove the piston so you don’t break a piston ring land by pounding them out.------------------- Read it HERE in the Engines Tech Tips sub-form. If you have any questions or comments about this Tech Tip, please feel free to post in the ENGINE SHOP forum.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
