If drilling the frame for any reason, drill only in the web, not the flanges. The web is the vertical part between the horizontal flanges.
Ed Pruss
Thanks Ed, I should have mentioned that. The shackle bracket holes on later frames using the 4-point cab mounts are in the web. If dogdaddy needs location dimensions for those holes, I can provide them, as my cab is not yet mounted on the frame.
