7 members (Otto Skorzeny, klhansen, Hotrod Lincoln, 3800GUY, farmallb, Rustnut, 1 invisible),
70
Mod | | | Forums66 Topics128,079 Posts1,056,301 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I've only used it once on front axle king pins and it didn't help but then neither did anything else. But I did notice that after a week or so it separated into two layers that you have to look at closely to see. Does every one re-mix before using?
Harold Wilson 41 Chevy 3/4 Ton
