1 members (klhansen),
136
10
Mod | | | Forums66 Topics128,281 Posts1,058,470 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | High octane fuel burns more slowly than regular- - - -sort of like running slow-burning smokeless powder in a "magnum" rifle with a long barrel. It's not really needed or useful in a low compression engine like a stovebolt. You're likely to see much higher temperatures in your exhaust system, as some of that high priced gas does some of its burning between the engine and the muffler, and the exhaust valves won't like it.
Try doing a pressure/volume/vacuum test on the fuel pump- - - - -I suspect that the inlet and outlet check valves in the pump have gone south. There are several places that are highly recommended by members here that will rebuild your pump with ethanol-friendly parts. Good luck! Jerry
