Try these- - - - -you'll need to fabricate something like a 4-link system to position the axle, but the weight capacity looks right.
www.ebay.com/itm/121872996666?
OOPS! That one's got independent suspension, not a straight axle! Just fabricate upper and lower supports to substitute the air bags for the coil springs. You might need to adapt to an outboard shock absorber if it's through the center of the spring.
