| | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,817 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,817 | There's enough slack created by loosening all the main bearing caps to pull the upper seal out with a big sheet metal screw threaded into it. The tricky part is getting the new seal pulled into the groove over the crankshaft. Lisle Tool Co. used to make a "Chinese Handcuff" tool to pull the new rope seal into place. The success rate for stopping a leak with a new seal was around 50% in most of the shops I've worked in since the late 1950's. There's quite a learning curve involved in getting it right most of the time. Jerry
