| | | Forums66 Topics128,035 Posts1,055,570 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | You don’t need to bench bleed it first Do you think the factory would be messing with dripping brake fluid? And if you bench bleed it Do you think you can install it without air bubbles in the master or the lines? There are two holes in the master between the cylinder and the reservoir You will not be able to trap air in the cylinder unless something is already wrong Put the thing on dry and save a mess Then bleed it on the truck Just like the factory did I’ve done this many times It works every time Do not over travel the piston Do not install it from the wrong end Just follow the instructions in the manual And everything will work out perfect like magic -s | | |
