I personally like the Old Air Products setups better than Vintage Air: https://www.oldairproducts.com/product/inside-package-1955-59-chevrolet-pu-ip-9100
With that kit, you can put whatever underhood parts you want.
You might be able to make a newer stock GM HVAC unit work, but it would be a lot of time taking measurements and looking at different models. Most newer stock systems will have the outputs in places that are inconvenient for the older trucks, but you might be able to save some money by doing a lot of work.
Whether or not that is worthwhile to you would be your call.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
"Frank" gets a new lease on life
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
The Saga in the DITY Gallery ~ and the story continues
