Ok thanks. I have a 94 s10 in the weeds. 2.2L 5spd. Im thinkin that should work. Then just have to figure out driveshaft to rearend.
You’ll need an adapter to match bellhousing pattern. Earlier s10 t5s have the right bolt pattern. There are some input shaft considerations and couple ways to skin the cat.
A 94 would also have electronic speedometer, so you would lose that function without some further mods.
Go find Lugnutz’s profile and view his webpage on T5 swaps.
