Doug,
Is this the
"...tech guide..." (Turn Signal Tech Tip) you are referring to???
If so, have you read the descriptions below the 3 sample charts to understand what the marks mean using the "continuity" test results in your charts?
The marks indicate wires that have continuity (for lack of a more detailed description a circuit for each light fixture/component) depending on the position of the switch (Off/Left/Right). I think to make sense of it all, you need to identify which colored wires you have listed go to which component and then you can hopefully correlate if each circuit is correctly wired.
I'm certainly no expert in this and hopefully another member may be able to better explain what you have.
Dan
