1 members (klhansen),
92
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The wood allows the frame and bed to flex independently with out much squeaking or wearing of metal to metal.
If you weld them together the frame will not flex as it should, cracks will start to appear. If you don't use wood, the steel will rub on the steel and wear and make noise.
The wood was, and still is, a good idea. | | |
