11 members (jmoore, Bucker, Jay R, 55shaker, 3B, papas52, 2-Ton, Joe H, GMCJammer51, sron48, Shade Baby),
105
2
Mod | | | Forums66 Topics128,157 Posts1,056,894 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,505 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,505 | You can use an inch-pound torque wrench (I prefer the old pointer style) to determine your bearing load and once that's done you can pinpoint your high center spot (sector/worm). You can also count turns and divide by two but I prefer the torque wrench. Takes any guesswork right out of it. When you approach high center, you'll see the torque wrench needle start to move and then at high center it will usually increase by about 10 inch pounds if all is good. Good luck!
