7 members (Otto Skorzeny, dt235sd, FAST55, FishinToms53, 3B, Rusty Heaps, 1 invisible),
100
2
Mod | | | Forums66 Topics128,115 Posts1,056,632 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | I have a Question about decent used clutches. Recently (like a day ago) I removed to inspect the clutch from an engine and bell housing that I plan to use in a farm truck The clutch is a 10-3/4 inch size for a 1 to 1952 gmc 3 of 6 springs in the clutch disc center are broken but complete No bits fell out So I went looking in the used clutch pile in my shed And most of them all have a broken spring or two Is this actually super normal and I shouldn’t worry about it for a beater farm truck? These disks are not even fully worn out Or should I find a clutch disc with all good springs The engine it’s going on is a 235 and the transmission is the sm420 Thanks for any thoughts or advice -s | | |
