2 members (baldeagle, LAROKE),
26
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Be sure to check the torque on the manifold to head bolts frequently, and use hardened steel "SAE" flat washers between the bolt heads and the manifold. Anti seize compound on the bolt threads is also a good idea. The different expansion rates between the aluminum manifold and the steel bolts has a tendency to compress the gaskets and create vacuum leaks. Jerry
