| | | Forums66 Topics128,034 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2022 Posts: 81 'Bolter | | 'Bolter Joined: Apr 2022 Posts: 81 | I will say my 67 c50 came with 3 tanks 2 saddles and the in cab tank but when I got it it only had the in cab tank. It has a splitter valve that is on the floor but it has of course seized up but for my truck I am doing it as cheap as possible so I actually bought a 18 gallon boat tank and installed it on the side of the frame. At some point I am also going to be cleaning out the in cab tank to use with the saddle and do some electrical wizardy and have a switch and a relay to run to the fuel gauge and a solenoid valve. But if you just want the in frame fuel tank I know late 90s 1 ton fords you could get a 40 gallon tank in them so might be worth looking into.
1967 Chevy c50 327 w/ sm465 5000Ib front 15k 2 speed rear w/ 22k springs, single axle, hydraulic brakes
