This just popped up locally and I’m no where near this part of my build. I haven’t done any research or know a lot about this so I’m here asking.
Can I put a ‘57 chevy Saginaw 4 speed behind a ‘60 261 as a direct bolt on? Going in a ‘46 1/2 ton with the torque tube rear and a 3:55 r&p conversion. I have the ‘46 bell housing and trans crossmember. Running an 11” clutch. If it can be done I assume the torque tube needs to be shortened and and some sort of adapter used? Probably a little floor modification as well.
Asking $500.??? I know nothing of trans prices or availabilities. A few pics with all the numbers for reference. Thanks for your time and help.
Ed
