| | | Forums66 Topics128,077 Posts1,056,013 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2022 Posts: 70 'Bolter | | 'Bolter Joined: May 2022 Posts: 70 | I’m currently taking a body shop class and we discussed burn through. As the other posts said, just re-prime and go easier on the sanding. For burn through it’s common practice to touch up the burn through with a rattle can if you only have a few small spots. BUT, TO GET PROPER ADHESION it must be the same manufacturer and type of primer. For the work I’m doing on the bed steps of my ‘55, I was able to get the same Nason primer in both a quart and rattle can from our local Kemperle Inc distributor, for the situation that you’ve encountered.
1955 Chevy 2nd Series 3100 Stepside, 235cid
