0 members (),
132
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,276 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | There are only 3 data points needed to adjust the PCV design to a specific engine (in addition to the fittings). 1. ID of the high vacuum orifice 2. ID of the low vacuum orifice 3. spring tension which determines where 1 or 2 is correct. The PCV from a similar-sized L6 in mild tune is a good substitute. | | |
