7 members (HandyAndy, MickeyP, Gdads51, k2handyman, chevy51truck, Otto Skorzeny, 1 invisible),
60
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Dieseling during shutdown is caused by an idle speed that's too high. Adjust the carburetor correctly and the problem will go away. Mixture and/or ignition timing has very little to do with the problem. If it won't idle somewhere around 500 RPM, fix the carburetor or find the vacuum leak. Jerry
